GE 90-30, CPU 363, plan for logic equal for today's service call.
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I have a customer who has a 90-30 on a Ferry Rotomold machine. I've worked with him before to troubleshoot some issues. I uploaded the file from the PLC to my Profacy Machine Edition, but couldn't get logic equal to go live. I hesitate downloading the program I uploaded because I don't have a backup plan if something goes wrong.... until now.
He bought a refurbished CPU 363 that matched firmware with the current CPU. I'm going there today to remove the old CPU, set it aside, and install and download the file to the replacement CPU.
I'm still a rookie with the GE PLCs. Are there any little "gotchas" that I should know about? I think one that I remember... upload *everything* when I'm making the selection, right?
On the phone he said the current CPU is "blowing fuses". Not sure how PLC literate he is, and whether he's using the right terminology. He makes it sound like the CPU card is blowing fuses. Does that make sense?
The battery that backs up the CPU's RAM memory is located on the power supply module. If you remove the existing CPU and set it aside for more than 20 minutes or so, you risk losing its memory. There is a place to connect a battery directly to the CPU module. Remove the front cover and it is between the keyswitch and the LEDs.
The "PLC blowing fuses" sounds like an overload in an output circuit, although there is a fuse on the power supply module. You have to remove the front cover of the power supply to get at it.
Definitely upload everything from the existing PLC, especially the program and hardware configuration. Uploading variable values will take longer, but it could be vitally important. All too often technicians write values to variables during startup of the machine but fail to provide a mechanism to allow the machine's owner to modify or even initialize those values. Worse, there may be no documentation, so you don't even know you need to be concerned about them.
Continuing saga from an earlier service call... My customer has a machine with a 90-30 PLC. We couldn't get logic equal by uploading the program...
3,597
I'm checking on an issue my customer is having with a refurbished CPU that we just installed. I downloaded the program, checked the save to flash...
2,172
Hi I have three meters one is GE PQM2 and other two are Schneider PM5310, GE PQM meter is communicating and im abale to read modbus data as well...
2,004
Hi there Im struggling to establish modbus communication with PM5310, I am using COMMREQ function block with below command block format Word 1>7...
1,972
Hi, I am looking for CPU 363 but it is not easily available. Can i replace CPU 363 with any one the following? CPU 350 CPU 351 CPU 352 CPU 360 CPU...
2,686
