Ge 90-30 cpu
chago
Sep 2018
mexico
Hello all
I have a GE CPU IC693CPU331-CE When I try to upload the program show There is no current program logic stored in the PLC , but shows the name of the program , I upload with Versapro 2.4 and Cimplicity , on the emporm Socket there is not chip place on it , some body lift the CPU wile it was turn on will be erased the program ? there is other way to recover the program . unfortunately no Backup program
Any Help Will be Great.
Chago
What is the name of the program? When the PLC loses its memory it reverts to the default name of "HHP".
If someone removed the CPU module from the base plate for more than a few minutes that would cause the RAM memory to be lost because the battery backup for the RAM memory is located on the power supply module.
For that CPU model (CPU331) without an EEPROM, once the program is gone from RAM there is no way to recover it.
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
39
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
66
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
54
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
128
