GE 90-30 Plastic cases
Corsair
Dec 2020
Missouri
248
Just looking for comments here - does anybody else seem to have above-average problems with cracked plastic on old 90-30 equipment?
We had a 364 CPU where the the case was so brittle that it shattered. Some of the I/O module retaining stuff breaks pretty easily.
I guess the problem is not unique to GE. We just ran a service call on some 30 year plus old Symax that seemed to break everything that was touched on the I/O module wiring arms. I don't remember them being that fragile when they were installed.
Power supply capacitor aging seems to be related to intermittent shutdowns and memory scrambles in older stuff.
Even wire has a finite usable lifetime.
There appear to be more reasons to change out really old stuff besides hardware and software obsolescence. We've got a Symax install with close to 40 years on several UV Prom CPUs but the customer hasn't got the budget to change. They manage to solder triacs into the output cards and keep going.
It really hurts when you keep telling them that they need to change the stuff and when the inevitable emergency comes they do it with someone else.
I have noticed that in general, plastic gets brittle with age. Heat probably has an impact as well. And it's not limited to GE.
Sometimes it's harder to get a PLC upgrade included in your budget than to get approval for a brand new machine. The new machine will almost certainly come out of the capital budget, while the bean counters may try to push the controls upgrade into the maintenance budget.
Hello everyone, I need to install a level sensor in an existing plastic tank. It will go on top and there will not be pressure on it except if...
7,355
I'm trying to work through a question I have about using a PLC, plus separate temperature and pressure controllers on a plastic extruder rebuild...
2,991
Good Morning , Do you folks know of any Laser Manufactures that excel in the cutting of plastic film ? We are looking to upgrade our...
1,375
please can you help me to find these screen for blowing plastic machine thanks
1,606
Good morning Everyone By any chance, do you know what's the brand of this type of cable tray? I'd like to know from what provider I could get...
2,046
