GE CMM321 used as Modbus TCP/IP slave!
I is a noob
May 2009
Eunice, NM
219
Have a CMM321-KM ethernet module but can't find in the user's manual how to make it a slave. Need to poll it over a modbus TCP/IP network. Any help?
It appears that Modbus slave/server operation is native, according the gfk1541b manual
http://support.ge-ip.com/support/index?page=docchannel&id=DO213
chapter 4 note:
(page 116)
As in it needs to have an IP address that i can poll remotely to obatain vital information. The 8 page document that came with said device says that this version provides Modbus TCP/IP master and slave functions and refers to GFK-1541(b or newer) as the user manual. The one i found say nothing about slave options and is basicly a how-to on setting ths module up as a master.
Once you have the IP address set, there shouldn't be anything you have to do to make it a server.
From GFK-1541B, page 1-2: "As a “server” the
Interfaces respond to requests from other devices such as PLC programming software, a Host
computer running an SRTP application, or another Series 90 PLC acting as a “client”. No PLC
programming is required for server operation."
I'll keep this as brief as possible, but it is a long story. I've been programming 90-30's since the late 90's. Haven't used them much lately but...
4,799
So I found out that the CMM321-EE does not support modbus tcp. So I guess I am now trying to figure out how to communicate to a GE 9030 rack thru...
2,746
Is anyone familiar with the AAIU to RJ45 adapters for CMM321 modules? These modules are now obsolete but I had to add some ethernet modules to a...
1,657
Hello! I'd like to know if someone can help me. I have a GeFanuc 90-30 with a CMM-EF module installed. The problem is that I need to communicate...
2,043
I am having a lot of trouble finding any of the necessary information on this card. I am trying to change the IP address via hyperterminal. I am...
2,665
