GE Fanuc CPU 350 , can't find connection port
Ahmadbasha
Jan 2010
EGYPT
30
I have in work GE Fanuc CPU 350 , can't find connection port to access this CPU ,,
As you can see , no port to access this CPU ,, can anyone Help me
The serial port to access it is there, but the connection is in the power supply that is next to the CPU when plugged into the rack. The path is completed through the back plane.
You need to plug the CPU onto a GE Fanuc back plane, with an PSU.
The programming port is on the GE Fanuc PSU unit, like RussB says.
Dear Marc,
Thanks for ur reply. I have redundant 90-30 series cpu which i need to communicate with Data Panel 45 through Modbus communication. Could you tell me the Pin configuration details to make communication between these two equipments.
Dear Marc,
You should have started a new post for this.
The DataPanel 45 has an RS-232 port pin 2 is Transmit, pin 3 is Receive and pin 5 is signal ground.
You will likely need an adapter from RS-485 to RS-232 or maybe the "Cheater Cable" will work but no guarantee on that.
We have a machine that we need to get running that has a GE Fanuc 90-30 PLC with a 350 CPU. It also has a Motion Mate DSM302 module. What would be...
6,316
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
174
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,053
I'm working on a 90-30 PLC which keep losing its program everytime it is powered down. We first figured it must be a battery issue, so we tried...
1,310
Hi guys. Im a total PLC noob. i suspect a dead 331 cpu. Unable to communicate with it using the LM90 start utility. But i could on another CPU...
2,931
