GE Fanuc Micro 90 PLC
techcontrols
Mar 2013
India
Hi
I'm new to GE Fanuc PLC's. I have a
IC693UDD104AP1 Micro 90 PLC (14 IO's). Can someone please help me with what software I would be requiring to program this PLC (Logic Master or Versapro)?
Any useful manuals will be helpful.
GE Micro PLC
The older firmware on the PLC may restrict your use of VersaPro on the Micro. Using Versapro, you can still store to the PLC but I have noticed that older firmware on the PLC will prevent viewing the live-action on the ladder logic. Logic Master DOS PLC programming software (LM90) works on the older firmware as well as the newer firmware. Also on the larger form-factor Micro, the one with the second serial port, the second serial port only works as an RS422 port verses an RS485 port. It does work great as RS422 on both older and newer firmware versions though. LM90 PLC programming software works with WindowsXP but chokes on Windows 7.
Hope that helps -Chris W
I see that the old IC693Uxxxxx GE micro which has been replaced by the newer IC200Uxxxxx Micro and Nano. The older IC693Uxxxxx series are plentiful on the surplus market and the price is certainly right. -Chris
Every time i turn off and turn on the PLC, PLC is not going to RUN mode In the fault table it shows error " system Configuration mismatch" And...
1,768
can somebody help me with the motor connections to this PLC.I am trying to develop a STAR start DELTA run mechanism that will be controlled by...
1,981
Hi Members! We have a machine which is controlled by Ge Fanuc IC693 UDD110 micro plc (not versa micro). It worked properly so far, now it is...
9,896
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
164
A few weeks ago while walking through the back part of our plant an coworker and I found an old GE Versamax Micro PLC (IC200UDR005-BB) on the...
2,490
