GE Fanuc Micro Comms and Proficy
tlbates
Feb 2012
NH
I've got to replace a Fanuc Micro IC620MDR014D 14 point PLC that has an "intermittent" run/program switch. I want to download the logic from the old and reload into a new PLC, but have never seen one of these little jewels. I have Proficy ME 7.0, but am unsure how to make the comms connection or if I can even use Proficy. It appears the brick has an Ethernet connector for comms. The original programming ladder diagrams state it was written with Versa Pro, but no other information is available. Any suggestions? Thanks, Tom
This link is referencing a different Micro.
The one in the OP is the VERY old (first Micro) unit that GE sourced from someone while they designed the Series 90 Micro which is also obsolete and retired.
The Software for the IC620 Micros is no longer available anywhere that I know of so here it is in the .ZIP below it includes an update to version 243.
Link to manual with cable pin assignments from Post # 2 above:
http://prz-rzeszow.pl/~tomz/Teoria%2...c/gfk0803b.pdf
BTW there is no support on this. The 'ReadMe.1st' file here has a 1993 date. It just may be older than some of the people on this forum. :)
I suggest you re-write the program in a different PLC. I have converted a few of these into the newer S90 Micro from GE, which is also obsolete now. For those it was best to work from a Sequence Of Operations description of the process rather than attempting a rung-for-rung translate. YMMV
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
151
A few weeks ago while walking through the back part of our plant an coworker and I found an old GE Versamax Micro PLC (IC200UDR005-BB) on the...
2,484
Hi. I have an Ge Fanuc Controller versa max and need to know where i can download the software for this PLC, anyone that can direct me please. I...
1,211
Every time i turn off and turn on the PLC, PLC is not going to RUN mode In the fault table it shows error " system Configuration mismatch" And...
1,758
I hope there is someone out there that can help. I recently inherited 35 Magnum presses (circa 1995) that have GE Fanuc Series 90 micro PLC's...
6,882
