ge fanuc versamax connection to laptop
spfpneumatics
Jun 2016
Philippines
i currently have a ge fanuc versamax micro controller and versapro as its software. i tried connecting its cable to my laptop through usb to rs232 male connector. the plc does not seem to connect. i tried serialcommtest and the result was "PLC Connected OK at 19200/Odd/1 use VPv1." what shoud i do next? it still does not connect to my laptop. thanks.
When you try to connect to the PLC you are given a choice of which devices to use. Under "Tools/Communications Setup" take a look at the settings for the device you want to use. Make sure that the adapter is installed at the same COM port that the communications device uses.
It has been so long since VersaPro was declared obsolete that I can't tell you whether or not to expect success with a USB/serial converter.
Uninstall VersaPro and re-install it then it will be fine but when you re-install see below, if you dont install it in 'Compatibility' then it will not communicate it will load and look ok but it will not connect to the PLC
I recommend that you contact your local GE dealer and request a Trial Version of Proficy ME. That will get you started and introduce you to them for future support.
Hi, I'm trying to connect to a GE Fanuc Versamx PLC, P/No IC200CPU001, using either straight through 9-pin serial RS232 cable to port 1, or 9-pin...
6,514
Distance between this two plcs is 2 km How i can share 4 anolog & 8 digital signal on 2 way communication . I am using Indusoft SCADA with...
3,439
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
229
Hi. I have an Ge Fanuc Controller versa max and need to know where i can download the software for this PLC, anyone that can direct me please. I...
1,217
Hello, This is probably an easy question—or at least I hope it is—and it will show how green I am. I've been tasked with troubleshooting a GE...
3,290
