GE Fix32 WinXP ABR Driver Initialize
SNK
May 2004
Toronto, Ontario
885
I am attempting to re-deploy an old application on a new PC, and when I run the ABR powertool version 7.29 in WinXP I get the following dialog box pop-up...
"Error Refreshing Rxlinx Driver List
API Driver is not Initialized"
I am running Rslinx version 2.50, OEM (Because the 2.5+ does not function properly as per GE)
I can browse all of my gateway devices in rslinx, and drill down to the processor, and many other items OK, which to me indicates that the software is browsing OK.....
I had this driver working properly with the same setup, but with Win2K, but for some reason I cannot understand, this installation is acting weird.
On GE's website, it does say that the ABR 7.29 driver is supported under WinXP.
It does also state that Fix32 version 7.0 not supported under WinXP, but many have installations functioning in the field.
Anyone seen this before?
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,300
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,069
I was introduced to Intellution Fix32 scada software at one of my customers today. They have no support from the programmer that built this setup...
5,987
Hello all, I'm using Fix32 7.0 and I would like to communicate with an OPC server. As I understand I need to install an OPC client driver? Where...
3,444
Hi All. I have an old Windows NT machine that has FIX32 running on it. I've added a network adapter to the computer and now Fix32 Startup is...
1,481
