GE Series 5 PLC Conversion
edwin
Mar 2006
iligan city
I had GE Series 5 PLC and I want to upgrade it. My plan is to change the CPU using the GE 90-70 or any latest model [GE PLC] but utilizing the I/O module. Can you help me?
I recommend using the 90-30 and also update all I/Q while you are at it.
Unless you have hundreds of I/Q it will cost less to replace it than to buy or build a reliable interface from a new CPU to the old I/O. Then you still have obsolete I/O that is difficult and expensive to maintain.
I second Russ' recommendation. Series Five components are only available through dealers in obsolete hardware. As time passes, they are going to get harder and harder to obtain.
If you have to convert in stages, I think this will work. Install a Genius Bus Controller in the Series Five and use it to communicate the I/O to a bus controller in the new PLC. With that architecture you should be able to convert from Series Five to 90-30 or Rx3i I/O modules on a planned schedule. The drawback is the need to buy a Series Five and a 90-30 Genius Bus Controller for no other reason than to keep you running with the old I/O modules.
Hello All, I am working on an upgrade project to go from a PLC2 to the Logix5000 platform. I am having trouble opening some old backup files...
2,832
I trying to convert the Sharp PLC program to Mitsubishi Q series program, but i having difficulty to understand the function in the sharp PLC...
6,026
I am working on a project that currently has a 64mb FX3U Mitsubishi running at a scan rate of 88ms. In order to improve the scan rate we are...
4,646
I had GE Series 5 PLC and I want to upgrade it. My plan is to change the CPU using the GE 90-70 or any latest model [GE PLC] but utilizing the I/O...
3,344
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
138
