I always thought that gearboxes with big gear ratios (especially ratios of > 80) and that have an angle of 90 degrees between in- and out shaft are selfbraking (you can't drive the motor by pulling the outgoing shaft).
But recently in an installation we had a 90 degrees gearbox of gearratio 60 that was completely selfbraking, and another gearbox of 90 degrees and gearratio of 180 where I could rotate the outgoing shaft by hand.
What makes a gearbox selfbraking? In the past we more then once had a problem where we wanted a roller to be drive by a certain torque but the precision was inaccurate because of the ratio of the gearbox?
