Generic PLC programming software
Allen's nearly right; there never was one but it was called Cadepa. lolis
It was a FB (or maybe SFC, I only met it once) front-end which produced RLL for download. It produced large amounts of very inellegant code becuase it only used the simplest instructions from each PLC's instruction set.
Some UK integrators liked it because they could develop their code once and then use whatever the customers' favourite controller was.
Google/AltaVista search should tell you if it's still out there.
Also "Structured Text" comes close as it can be Imported/Exported with most IEC-61135 packages with minimal changes, but it's not RLL.
There was one once, it was called LogiCAD. You had to draw your program up as if it was an electronics schematic, and with a preprocessor/postprocessor combination it was converted to different PLC languages. I have one laying around together (since the mid 90's) with the processing parts for Simatic S5, but I never really used it, apart from testing it.
I just quickly googled for LogiCAD and it seems it's still available, but now it's based on IEC61131-3. The company is called Kirchner SOFT GmbH .
Kind regards,
Hi, My company has developed a standard product and I would like to be able to set up a way to provide some data out of that machine for...
3,769
Hello Experts, Once again I am here as could not find information. I am reading and writing to Modbus RTU device through Anybus communicator...
2,689
Is it possible to add another AB Rockwell PLC to the network tree as a Generic Ethernet Module and use it as IO? Any idea where I would find...
3,138
Hi All! I'm working on a project using a Micro 820 and an Ethernet/IP enabled distance sensor (linked below). Basically, all I have to do is pull...
3,459
Hi all, Hoping someone here has experience on ProSoft modules and using them with PLC-5s to bridge the gap between the old and the new. We've...
2,116
