Getting Data from rsview32 to Intouch
Aug 2009
Hyderabad
34
Hi
I would like to know whether I can browse tags from RsView 32 through OPC like Kepserver which is installed in someother PC in same network.
The basic idea is to get datas from Rsview 32 to Intouch.
Not sure if kep will let you link to RSV but if the RSV is fetching data via the network then kep could read the data from the plc, also kep has a client that could read data from the opc driver that RSV is using (assume you are using opc if direct comms in linx then no you can't).
Need more info on what server used on RSV pc & is it direct driver or opc, what comms from RSV to plc's etc.
it's unlikely then, but there may be a way to install the kepserver on the RSV pc, create the tags to read using the DH485 already setup (not sure if linx will co-exist on the same link then brouse the tags over the network with the other pc application.
All, I have a CompactLogix L33 and would like to get data from a height gauge. The gauge is a Fowler Sylac Mark VI with RS232 output. I can...
2,617
Hello I am hoping someone here can maybe at least tell me what I shlould read up on or if this is even possible. Rockwell Studio 5000 is my...
4,314
Hi, Guys I'm trying to upgrade a device witch comms is thru a RS232. The PLC is a Compactlogix L16ER to a remote PIO 1734-AENT then on this PIO a...
22
8,241
Hello Eveyone, I need your advice on one problem.I am using CompactLogix PLC.I am looking for some ways.So, that a PLC program can read data from...
26
13,998
Hi all, I'm trying to use the Data Preserve Tool for Logix5k (CompactLogix controller) but I keep getting comms errors and I'm not sure why. I've...
4,117
