Steve Bailey
How many people have to tell you that your backdoor approach is a lousy idea before you'll get the message that it's a lousy idea?
You are a HACKER! that's ok though.jarbar1026 said:..I work at a big food-manufacturing plant in the midwest. I've only been here a couple of months, so I don't necessarily want to give out my company's name. Nor do I see the need. I'm a .NET developer.
CIP or Ethernet/IP is open.Sheldn said:AB uses a protocol called CIP which is embedded in the data part of an IP packet. This is a Rockwell protocol and is not (I think) an open / published standard.
We paid $500 but I think it is free now.Sheldn said:I do not know if you can get this level of information from the manufacturer with out paying alot for it.
Read my post above.Sheldn said:You may have some luck talking to Rockwell about their SDK Software Development Kit. It is the base software that all others (Intellution, Wonderware, Others) use to develop their device drivers. The software will allow you to write your own code to get data from PLCs through the RS Linx software.
Steve Bailey said:RSView is capable of doing what you want to do. It is the correct tool for the task you've described. What I can't understand is why you're more afraid of crashing the system by using the correct tool than crashing it through the use of some some backdoor method.
Undoubtedly you do not get it, he already has RSView so why sniff etc when the data is already there?So aparanently you don't get it. Which makes it even more ironic that you're coming down so hard on this guy.
Confusing price and value as usual.The developer edition of RSView is ridiculously overpriced as are all of Rockwell Software's offerings
rsdoran said:Undoubtedly you do not get it, he already has RSView so why sniff etc when the data is already there?
