einnh
I have a two part question regarding reading serial information.
I am looking to implement a GPS antenna into my control system using something similar to this:
http://www.tigergps.com/garmingps19xhvs.html
This antenna uses NMEA0183 over RS232. I have never used serial data in a project and am curious how to read it. Is it just a stream of ANSI characters? How would I read the data into my PLC? Is there a special function block or bit of code to sort the data stream?
I have the stream format from this:
http://www.gpsinformation.org/dale/nmea.htm
I will be using CLX.
Thank you,
Thank you,
