Grabbing data from process analyst
josh_d
Jan 2011
Vic
20
Im trying to extract data from a process analyst object, to create custom trend controls.
The object exists on a citect page and onPageShow, I call a function:
FUNCTION ConfigurePA()
OBJECT hPanes, hPane, hPens, hPen;
STRING sPen1Comment;
hPanes = _ObjectGetProperty(ObjectByName("AN23"), "Items");
hPane = _ObjectCallMethod(hPanes, "get_Item", 1);
hPens = _ObjectGetProperty(hPane, "Items");
hPen = _ObjectCallMethod(hPens, "get_Item", 1);
_ObjectCallMethod(hPen, "GetField", "Comment", sPen1Comment);
END //ConfigurePA()
Im trying to extract the tag comment from pen 1, so I can display it on the citect page. However, It doesn't work at all and I end up with two errors.
ERROR1:
Error 274: DESC: 'Invalid argument passed'
ERRPAGE: '_ObjectGetProperty'
ERRDESC: 'ConfigurePA'
ERROR2:
Error 433: DESC: 'Cicode type mismatch'
Is it possible I dont have the function library included? From looking at the errors, Citect example code, and tinkering.. I cant find the problems!
Thanks for any help.
Your error is in this line:
hPanes = _ObjectGetProperty(ObjectByName("AN23"),"Items");
Check the syntax for ObjestGetProperty. It does not like either AN23 or Items. One or both are incorrect. Check to see what Properties Citect has available.
I've got 16-bit data at address 40200 on a Schneider Scapack 350. I can grab the data over Modbus TCP using Kepware at IP 172.16.1.100. When I...
2,501
I'm looking at trying to program Relay Ladder Logic to average out a value for X amount of time. In this application I'm looking to have an...
3,055
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
22
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
73
61
