Grafana - FT Historian
TWa
Mar 2023
Queensland
HI,
I was wondering if anyone has been able to use Grafana to connect to the Rockwell Ft Historian database before. I am really looking for some help if you have had success
Why would you want that?
Really just curious since Grafana isn't as powerful as the Historian is for trending. It's insanely powerful for the price, that I admit, but if you want to zoom in and out and do stuff ad-hoc it's somewhat painful in comparison.
If you are not already married to Grafana, then Thingworx would be a better dashboard tool to use with FT Historian, as it's a Rockwell product, and the integration is already done.
Thanks guys.
Only reason I am using Grafana is that it was a good free trend tool. I have FT Historian only so no FTView. Which would mean if I wanted to not have to buy any more licences I would have to use Vantage Point or Something else.
Thanks guys.
Ahhh, this makes perfect sense. I forgot about VantagePoint to actually serve the data and indeed it was a better visualization tool.
Here's a tip, FT Historian is OSI PI under the hood. Searching the interwebs netted me this:
https://grafana.com/grafana/plugins/gridprotectionalliance-osisoftpi-datasource/
Have a go and see if you can get it to work.
I've played around with Grafana and FactoryTalk Historian SE (Rockwells repackaged OSIsoft PI) for testing myself, and I've also been using someone elses install of Grafana talking to OSIsoft PI.
Grafana has the OSIsoft-PI data source plugin. (Search for osisoft in the Grafana Configuration\Plugin area)
That will need PI-WebAPI installed and configured to access the historian.
(Install kit is in the Redist\Advanced Server Options\PiWebAPI folder on the historian disk on 7/8)
When I played with it myself, it was a quick and dirty install, PI-WebAPI on an alternate port to avoid conflicts and I just used basic authentication.
Seemed to work pretty well on my test install, but I didn't read enough to make it production grade/secure, I only have end user access to a proper install.
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
147
HI folks: I am testing and trying to learn GRAFANA from https://grafana.com/ I like their graphs and interfaces (dashboards). Has anyone used...
4,039
I noticed that the new FTHistorian 9 only uses the PI 2018 still, and is not updated to 2023 yet. I figured by now any new releases would have...
194
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
152
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
70
