Grafcet / SFC transition delay?
SCADA_Dude
Feb 2008
California
115
I have reviewed the IEC 1131 documentation and previous posts, and cannot find a way to ensure a transition only executes if it's true for a certain amount of time. (Not to be confused with the time the previous action was true as in step1.T > T#5s)
For example:
When pressure goes above psi setpoint and stays that way for 5 seconds, then execute transition. If say after 4 seconds, the pressure drops back down, reset the timer to 0 and do not execute the transition.
Do I have to create a boolean and toggle that after the delay in a seperate section of the program? This seems like a messy way to do it, because I'd like to see the timer in the SFC...
Is this possible?
I'm not sure I'm following....But I'll explain what I do:
I typically put all my grafcet step/transitions in their own subroutine. Any of the logic required to initiate a transition goes in its own routine, including those that are timer related. So, in the grafcet construction subroutine, I might have:
XIC Step1.1 XIC PSI High Delay OTL Step1.2 Branch OTU Step 1.1
Then in my timer/counter routine:
XIC PSI TON 5000 Branch XIC TON.DN OTE PSI High Delay
You've answered my question thanks!
I wish there was a way to show\evaluate the TON in the grafcet, and not put it in a seperate subroutine - but that will work.
Hi Does anyone know of a nice to use (and possibly free) package (say like visio) that I can use to draw SFC charts for inclusion in a word...
16,137
Hello Enlightened Engineers, I am using PL7 PRO V4.5 (made by Schneider Electric) on a Premium PLC. I have to debug existing code in Grafcet and...
4,548
Hello everyone, Please forgive my ignorance, but I am new to the field of PLC programming. I would like to know if RSLogix 500 could be used to...
10,867
I was looking for free grafcet software, I finally found grafchart see here: http://hubpages.com/hub/Grafchart_Grafcet_SFC_software Anybody uses...
2,464
I’ve found SFCEDIT by http://stephane.dimeglio.free.fr/sfcedit/en/ a simple and reasonably priced Grafcet Editor for planning and documenting...
2,462
