Gray Code and RSLogix 5000
If you need to leave an indication of 0 at the same rotation point then test for 0 and if so transfer that to the result else subtract the indication from 360 and store the result.
Yeah... that's almost how I ended up doing it.
Attached is the code I downloaded into the MicroLogix 1100... that lowered the scan time back down to what it was before, as well. The encoder we usually use is the Koyo TRD-NA360NWD from Automation Direct, by the way.
Thank you for that explanation.
What is I3 input? 1762-IQ16?
What's the maximum speed for this application?
Exactly.
And the GCD instruction takes up the whole I:x.0 word, so even though the encoder uses only 9 bits, I:x/9 through I:x/15 are not available for anything else to use. I have not tried GCD on, say, half of a 1762-IQ32T card.
What we track (the 'work' cycle of 6 or 8-spindle automatic lathes) is typically 4-10 seconds (an eternity compared to high speed counter uses); But it's much faster to tweak degree windows via the touch screens rather than pulling safety covers, then changing cams or moving proxes/limit switches/actuators.
You could use an AND of 511 after loading the full input card value to preserve the lower 9 bits leaving the upper 7 free for other uses. Regarding the 76, the active counts are centered on the 0-511 leaving 76 counts on either side. Thus the 0 and 359 counts are still one bit change different preserving the essential quality of Gray encoding.
Hey guys, Although I've poured through this forum for help in the past this is my first post. I am looking at replacing obsolete Baumer IVO...
1,970
First time I have used an absolute encoder and it is definitely:banghead:. I have a Siemens 6FX2001-5FN25...
21
6,069
I am migrating a PLC-5 to CLX. I do not have the option of changing out the existing encoders (845D-SJHZ25AGCW4). 8-24v DC, 256...
1,607
Hi I have a question about a gray code absolute 8 bit encoder. The encoder is connected to 8 inputs on an Allen Bradley PLC. if you turn the...
2,274
Using RSemulate, according to technote 55723, i should be able to use the GCD instruction to test some logic but it seems as if its not working. i...
3,319
