Ground / Shield / Com and PNP NPN
okiebob
May 2002
McAlester, OK
98
This also relates to the PNP or NPN post, Here goes,the system designer used GND/COM/Shield interchangebly, fire up the motor and the T/C type J, goes UP a 100+degrees according to the display and jitters back and forth. First step find shields and gnd. Hmm chassisis is using 3phase input ground for itself ( this also is motor input ) and that is only gnd for a steel Van sitting on wood blocks first correction install gnd rod and cable to chassis. Now T/C is 10 deg high and still jitters (walks about 5 deg either way). All sensors in are IS and in own conduit, motor controls in another Unit, but still attached to Unit 1 via conduit. I hate ground shield GREMLINS, what the fun the AM is going to be, the start of a good day anyhow 1 step closer to payday.
Hi all, I need to send a 4-20mA signal from a PLC (ICLinks Everest) to a paperless chart recorder (Endress and Hauser RSG30) and I'm having a...
2,261
Hi Guys, The electricians accidentally pulled a two conductor cable for the RS-232 communications. The seals are poured. Is it okay if I use the...
5,285
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
509
Hello i can not change one of the displays background color, the "Apply" button is greyed out. the firmware 5.10(older PV PLUS1000). I can change...
1,207
We switched from a SLC5/04 to a 5069-L320ER, and the SLC's NI4's were replaced with the 5069-IY4, which is a pretty neat card; however, the IY4's...
1,756
