GX Developer Programming
thandie22us
Jan 2009
Johannesburg
18
hello
i would like to write a simple ladder program in (Mitsubishi)GX Developer 8, but i am not sure
1.where i get devices like the timers and counters etc,i.e i cant find the tool chest or library
2.the PLC seems to be always in run mode and i cnt find were to stop it so that i am able to download the program to it.
3. what do i do to monitor the program when PLC is runing
Basically can someone help me with the fundamentals of programing in the GX Developer environment. I have tried the manual but i seem to be stuck.
thandie22us
Some Mitsubishi PLCs have a hard wired run input.
If there is no switch on the front of the PLC look for a wire going from 24VDC to a terminal labelled RUN.
Timer and counter are accesed by typing "out TX KYY" or "out CX KYY" (leave out the quotes)
Where X = timer or counter (T or C) number 1-2-3-4-5 etc. and Y being the preset value in tenths of a second (represented by K (constant)
Marc
thandie22us
Also to monitor the PLC when in run, open the program in gxdeveloper, connect the cable to the PLC port.
Click on the "online" toolbar, scroll to "monitor" and select "monitor mode" or you can press F3.
To modify a running program follw the same steps but change "monitor Mode" to "Monitor" (write mode).
Marc
Hie Marc
Please see mu response in red below.
thandie: I am using an ethernet connection to communicate with the PLC
thandie: When i try to monitor it gives me an error "A melsec application error has occured. Please restart <ES:02000006>". what could be the cause of this error.
as for getting familiar with it, GX Developer has nice manual that explains everything. That should be first reading material when starting with Mitsubishi PLCs. not sure about that error, never seen one. what are you using for operating system (exact version and service pack), GX Developer, how much RAM you have etc.
Marc
I have found how to stop and run it through Online\Remote operation.
When i try to change a contact or coil from say an 'X10' to an 'M100', i double click on the contact then it gives me a small pop up window saying "find". This doesn't work. Where am i geting it wrong?
Where do i type "TX KYY"?
Where is the library or toolchest where all the instructions and operands are found?
I assume you mean "T5 K100" for a timer with a preset value of 10sec.
Marc[/quote]
i have two manuals that i am using but they are not giving me the basic fundamentals of working around the Gx Developer environment.they are
  1. Mitsubishi Q series controller software manual
  2. Gx Dev operation manual
Is there any other manual that u may refer me to
That should be first reading material when starting with Mitsubishi PLCs. not sure about that error, never seen one. what are you using for operating system (exact version and service pack), GX Developer, how much RAM you have etc.[/quote]
I am using MS Windows XP Profexnal,version2002, sevice pack 2, 0.99Gb RAM
thandie22us
My responses in BLUE
Thats good news, wasn't sure how old a PLC you were using
GXDeveloper defaults to read mode, you need to change to write mode. On the edit menu, scroll down to "write mode" or press F2
When you are at the output section of the rung (far right) type "out t5 k100"
In the VIEW menu, select toolbar and you will get a popup window that will allow you to select which tools to display. You want to make sure LD SYMBOL is checked.
Precisely
Marc[/quote]
Hie Marc
thank you very much for your assistance.
I seem to have one major problem, i cant monitor the logic in the GX Developer but i can seethat the logic (ladder diagram) is functional in the citectScada.
Suppose the citectScada is offline, how am i supposed to monitor the functionality of the logic in the GX Developer environment.
Everytime i select monitor mode or monitor'write'mode, i get an error and the gx developer becomes non-responsive and shuts down.
Not sure,
Have you checked that error code against a list of error codes?
Do you have the manual for the software?
Marc
GX can become unresponsive if the ethernet comunication settings are incorrect when going online. Check the settings under "transfer set-up" make sure the station address is not the same as the ethernet card station address. i normally set mine to 50 just to be sure.
Check your IP settings.
Hi everyone, I'm new to ladder programming and I may have been too ambitious thinking I could do a full plc program by myself. My father has a...
62
14,923
CX Developer Programming software Hey I want to download CX Developer Programming Software for omron PLC (Omron CP1E 14DRA). Please help me for...
1,636
Hey I want to download CX Developer Programming Software for omron PLC (Omron CP1E 14DRA). Please help me for the same Thank You
1,681
Dear friends,i am programming In GX developer for controlling of 3 booster pumps by 3 Danfoss VFDs based on water pressure in pipe,2 Bar is cut in...
2,772
Hey guys, I'm taking a course on PLCs for my BTEC and my teacher is shockingly incompetant to the point the he took 2 hours to work out how to...
3,886
