GX Developer timer command
Jhona
Oct 2016
Morelos
Hello everyone!
Could someone help me and tell me what the "D212" means?
I know that to define the*time of a TIMER you must put a k and number (miliseg).
Help.... :(
I've only used GX developer once (and it's a painful memory), but if it's the same as most other PLC's, you can define the timer preset using "K" - which means you enter a constant/fixed time preset - or you can have the timer preset be variable, and assigned to an integer value, like "D212".
So, the time preset of T1 is dependent on the value of D212.
Hi there I am currently translating a Mitsubishi program for upgrade to RSLogix5000. Could anyone please explain to me how the code in the...
2,259
Hi all I'm trying to program a 20 minute timer on an older Mitsubishi PLC with GX developer but the register does not allow it. For instances, T1...
6,611
Dear friends,in GX develop ladder logic programming how can i make off delay timer ?.
5,039
Hi, i uploaded program from one melsec PLC,in Program timer T1 K20,T2 K100,T3 K250 is given but for timer 11 T11 D8030 is used, what is that ?.it...
6,639
I am new to gx developer and I can't seem to get the proper syntax to set up a timer or counter. I have looked through the manuals but hey are...
2,653
