GXWorks and Passwords
Andrew Hardy
May 2010
Stockport
87
Hi
I have been given the job of modifying a project written in GXworks, the system has 3 HMIs, and alarm messages are stored as strings in the PLC - I have been asked to add some more alarms to the system - all fine and dandy - except that to read the data from the PLC we have to enter a password, which we don't have. We can upload the program no problem, but can't upload any data hence I'm not able to edit any of the current alarms and can't see where the spare alarms start.
Is there any way around this? - we have emailed the firm that wrote the software initially, but they have not been forthcoming (surprise)
Hi
If you don't have the password or access to it, but you have a copy of the program, you can clear the PLC and re-enter the code. That is about the only option I believe.
Hope this helps,
Dave
Thanks for that, we already have the program offline so just to be sure - we can clear the PLC, retaining the data, then just download the original program back into the processor?
Hi Folks I have made a function block that has the EN input enabled. (FBD language) In want to run some code at the top of the function block as...
1,749
Hello Friends I am a rookie in mitsubishi. I have many conditions in my program, How can I add several lines to a rung? For example: How can I...
1,527
i am in new of Mitsubishi software . while Installing the Gxwork 2 error code in pop up -5006:0x80070020. my lap windows 7 professional k 64bit .
950
I am trying to do a subroutine using a Q series (Q06UDEH) plc and GXWorks 2. The manual says to use a FEND and then start the subroutines. Each...
4,009
How does one return a value from a function (not function block) in GXWorks 2?
1,297
