Mitsubishi GXWorks How to add several lines to a row?
asteroide
Jul 2010
der
158
Hello Friends
I am a rookie in mitsubishi.
I have many conditions in my program, How can I add several lines to a rung?
For example: How can I put K0 at the right, K0 at the left?
K1, K2, etc?
I have search in documentation and internet, but without success.
Thanks in advance.
Place the cursor on the contact where you wish to insert a contact (this will place the new one before the one you have highlighted (blue box), then go to top menu\insert row. this will push them along & then you place your new contact in there.
To be honest, sometimes it makes sense to use an intermediate "M" bit in the logic then use this in the next line.
Like in the second pic attached.
Hi Folks I have made a function block that has the EN input enabled. (FBD language) In want to run some code at the top of the function block as...
1,735
I am trying to do a subroutine using a Q series (Q06UDEH) plc and GXWorks 2. The manual says to use a FEND and then start the subroutines. Each...
4,001
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
41
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
