Has anyone used the Wago CC100 ?
Ken Roach
Apr 2002
Seattle, WA
17,480
I've been getting some advertising related to the attractively packaged Wago Compact Controller, model CC100, lately.
As far as I can tell it's a small packaged version similar to a 750-series controller, running CodDeSys 3.5 with some onboard I/O. It might be similar to how CompactLogix L16 has "local" I/O that is really just POINT I/O modules in a fixed assembly.
Instead of offering "e!****PIT" for programming, Wago is providing a Device Support Package that you can install into a stock CoDeSys 3.5.16 (or so) development environment. The actual part number that shows when you create a new project is "0751-9301 WAGO Compact Controller 100".
I can't figure out pricing or actual availability: Wago tells me to call my distributor, but none of the distributors in my area that carry Wago product actually admit to carrying Wago PLC hardware.
I even saw a YouTube video from Kurt Braun, Wago's excellent Internet marketing engineer, showing how to disable the CoDeSys runtime and use the controller with Node-Red instead.
Has anyone else on the Forum taken a close look at these little controllers ?
I have just started looking at the CC100 as a possible replacement for Micrologix PLCs.
They look more than capable and has onboard OPCUA comms which is what i am looking for in a new small controller.
I have ~50 units currently commissioned and in use. They work well, and are currently available. Only problems I have had has been with the LED indication lights in the front that suddenly stop working and then come back.
Hi all, I have a client that has a water tank with a loop powered level sensor; the 4-20mA loop goes through a telephone line, half a mile away...
26
6,984
I'm working on a temperature/humidity test chamber that was made in China sporting a TATO PLC that looks exactly like a Micrologix 1000. Also has...
3,286
I have been scouring the internet over the past few weeks trying to learn about Hart-IP. Does anyone know, if I have a Hart-IP device, should I...
3,131
Whilst browsing the ODVA website, I came across CompoNet. Has anyone heard of or even used this protocol before...
1,861
Has anyone used the Kollmorgen KAS HMI? Comments? How's the programming - good, bad, average? Any general performance feedback? Has anyone...
1,553
