HEllo again plc 5/20 cpt what am I missing
controlconcepts
Oct 2008
boston
300
have not had much experience with logix 5 and just trying to use the y=MX+b equation to do some scaling in my test rig. The rungs in question are 19,20,and 21 have read many posts on the subject and banging head...... also used same eq in a slc and am not getting the expect results. must be something easy. just looking at it to long. need a fresh set of eyes.
Thanks to all that respond no rush but know how you gurus pick up on this stuff. And thanks to all the others that have helped me last time.......đź‘Ľ
Can you Post your Program File (RSP) so we can see what is in the N Files. (Zip it first - Forum rule)
Stu....
a solid hint ...
the figure below should help with the basic format of the formula ...
note also that if you stick with ALL/ONLY integers in your CPT then you're going to have problems with "round off" errors ... you need to have at least one floating point location in there somewhere - possibly more depending on the values that you're working with ...
there isn't enough information in the PDF you posted to allow me to use your specific memory locations ... you should be able to substitute your own locations for the samples that I've used ...
Sorry it took so long to get back to this post! Thank you all for help. And Ron great to see you back here with your inexhaustible fountain of knowledge. But I tried the formula that you posted and still not working. I am getting ridiculous results. I will post the RSP file and maybe this will make sense
And I forgot to explain the regester mapping I am asuming
Ron's CPT integer's my integer's in my CPT lad 2 Rung 19
n10:0 = input N14:140
N10:1 = in min N14:141
N10:2 = in max N14:142
N10:3 = scaled min N14:143
N10:4 = scaled max N14:144
Break your calculations down into managable pieces that you can check against your hand_written-calculator_checked design notes. I usually find I fat fingered something somewhere.
Wow someone else that uses the fat finger term lol. ya found my
(in min in max)
(scl min scl max)
swaped in the eq set Ron posted
but still off but very close pointing to the analog input card needs A CALABRATION
As i have the AI"s looped to a slc 5/04 card and the numbers are exact on them.
in the PLC 5 @ 4 ma raw counts = (2070-2085) never steady always bouncing
I have a PV1000 Color Touch 2711-T10C10 and it has the DeviceNet option card. I have found a DH+ comm card for the same type of PV. My question...
1,740
Could one of you plc gurus explain to me,or show me in ladder logic terms how to use the (strn) command i have direct soft5 software and a 205 plc...
1,498
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
120
I want a free plc programming software that is available for download onto laptop or pen drive. I have read books at length, I want to do...
16
4,115
Hi guys. Im in need of some help. Im working on a down hole tool. one of the sensors failed and it is stuck down hole. I cannot find a way to...
2,232
