i have problem with siemens fm 350 counter module on a s7-300.
the "cr" lamp is off all the time, and the lamp "dir" always on... so the counter is not synchronized and the programm is not running properly... i thought that the encoder was broken and i change it without any result. so i change the counter also and again nothing..
the problem remains... so,any idea what to do or what seems to be the problem????
or at if you could tell me how to adjust the encoder( simple, 3 outputs, rottary)
maybe the adjustment is the problem...
if you know anything please tell me... any idea, i should try, to make this work...
