craigw Member C Join Date Jun 2005 Posts 1 Jun 13, 2005 #1 What do I need to hook up a slc 500 to a new laptop without a 9 pin rs232 connector
rkukl Lifetime Supporting Member Join Date May 2002 Location USA MA Posts 194 Jun 13, 2005 #2 I would say you have a few choices. 1) Try USB to serial then use serial cable. I have always used the AB cable but I think it simply a null modem cable 2) PCMK card and cable. Look on E-bay they usually have some listed look for series B and appropriate cable 5/03 or lower or 5/04
jimbo3123 Member J Join Date Sep 2003 Location Detroit Area Posts 550 Jun 13, 2005 #3 What model of SLC is it? 5/02, 5/04, 5/05??? They have different communications options.
jolio ST Member Join Date Oct 2004 Location central CDC Posts 292 Jun 13, 2005 #4 I assumed you are talking about SLC 5/03 onwards cos those are the models with the RS232 function. You could always use the DH485 channel, with a 1747-CP3 cable. I believe most laptops have the RJ45 pluggin. regards Sherine T.
Alan Case Lifetime Supporting Member A Join Date Apr 2002 Location Wagga Wagga Posts 1,268 Jun 14, 2005 #5 Search on here for Keyspan. They make a USB to serial adaptor that does work and will autoconfigure for DF1 protocol. Regards Alan Case
