Help deciding
Chonwell
Jul 2005
Viña del mar
Hi guys,
I need some help deciding on what PLC should I use.
It's for controling some pumps and stuff. I've worked several times with PLCs, but now I need to be able to programm and control it through RS232 or RS485 from a java programm. Cost is very important!!
I've been looking into the mitsubishi's FX family an the Simatic S7.
Thanks !!
well i depends on the number of i/o u are using
if it is small u can use an s7-200 + it communication processor
if bigger use s7300 or 400
u must at least specify the number of i/o u need
The number of i/o is not an issue.
What I really need to know is how to program and control the PLC from a java aplication, not from the manufactures app.
Are you wanting to just change the values of certain registers and bits or timers from the java app, or are you wanting to create, edit, and downlaod the ladder program from a java app. The first will be relatively easy, the second will be very difficult.
Hi guys, I need some help deciding on what PLC should I use. It's for controling some pumps and stuff. I've worked several times with PLCs, but...
1,898
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
97
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
461
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
173
67
