Help getting RSLOGIX 5570 emulator off the ground
ABnewb
Sep 2016
VA
25
I'm trying to set up a 5570 emulator so that I can write logic and test it without the actual hardware. However, I'm not able to go online with the emulator's processor.
I've attached a screen shot. I"ve added the Emulate 5570 controller in slot zero of my virtual backplane. I've also configured the virtual backplane driver in RSLOGIX. However, I can't connect to the 5570.
Am I missing something obvious?
Your emulator processor is occupying slot 0.
The slot # must match with the processor you setup in rslogix emulate
Also i see you are using v29
Last I checked emulate 5k latest rev supported is v24 so you will need to run this fw version.
Every video I've seen referenced the chassis monitor that you referenced in your screenshot.
Although I have the professional edition, I can't seem to find that monitor anywhere. Is that a separate download? Maybe I don't even have the complete emulator?
Yes, "professional edition" is referring to Studio 5000 Logix Designer. Studio 5000 Logix Emulate is the name for the emulate package. It used to be called RSLogix Emulate 5000. Either way it is a separate software package that must be installed for you to use it.
OG
Hello All, I’m trying to get online with a local lift station L32E compact Logix processor to pull the program as the local municipality cannot...
26
5,057
Good Evening , After running for 2 years , I have a few Powerflex 525 drives faulting out with a F 73 Ethernet Fault . What have you guys...
2,592
I need help getting this program into a PDF. I don't have access to RSLogix 500.
2,596
Hello Gurus, I have started teaching myself Allen Bradley PLC with RSLgoix 500 and LogixPro with grateful and helping comments of you gurus...
3,989
Hey guys, I'm at a waste water treatment plant trying to get their UV system running. I've traced the problem down to a AOI that's causing the...
2,682
