HELP Identify a PLC please!
yorkypaul
Oct 2007
Leeds
Can anyone identify the PLC in the attached photo? I'm after info and spares so any help with a manufacturer would be a great start.
Markings on unit:
"CPU 166F", "D18", "PD03" and on the white I/O modules "Z02 Universal PLC".
Thanks in advance,
Paul
I am not 100% sure but from what I see in the photo it appears that it is not a PLC but rather a remote IO unit. The two communications type ports, the one at the top with a 9 pin D shell connector and the lower one that has wires connected to a terminal block. Can you tell me where these go? I would suspect that one of these goes back to an actual PLC somewhere. Just some thoughts. Have a nice day.
Thanks MrTweaver,
The D connector is to a VERY basic HMI, and the wires are supply voltages. I believe it is a PLC, but apart from I think the machine is Czeck, I don't have much else to go on, as you can see.
Thanks again,
Paul
It definately looks like a PLC of sorts but not one I recognise. No Clues on the drawings I suppose? Any point in asking the machine manufacturer?
Nick
Hi Paul,
o_O hmmm, can't see much from that blurry photo...
Do you have any other info...
  • A backup file or a printout of the PLC program?
  • Any electrical drawings?
  • Who is the manufacturer of the machine it controls?
  • What does the machine do/make?
  • Have you posted exactly what is printed on the components? (for instance "D18" is more likely to be "DI8" for a 8 way digital input module).
The more info you post the more likely you are to get a useful reply.
**edit**
Ooops cross-posted a bit with Nick there...
Hi Nick.
The machine is a Uniko. I have no drawings whatsoever. The "Universal" modules have inputs from strain gauge modules, and the outputs control assorted pneumatic valves to deliver required weighs repeatedly into a flowwrapper (making bags).
I'm heading towards a dream of being able to look at the prog in this thing?
Cheers,
Paul
Hi guys. I need some help identifying this plc. It´s rebranded by an oem manufacturer and I would like to upload a backup in case of failure and...
2,150
All, I attached some photos of some equipment that I picked up at an auction, but I'm having some difficulty identifying it and finding any...
17
6,270
I have about 60 electrical enclosures (8" x 10" x 6") that I want to get replacement doors for. I have been looking through online catalogs but I...
3,648
any input would be appreciated! we had one over head conveyor system, we need to identify every moving mustache position at loader and unloader to...
2,102
Hi all. First post and of course it's a question begging an answer. I am finally getting back into PLCs after years of Field Engineering. I'm...
1,782
