HELP! Installing Rs logix 5/500/5000
Timeismoney08
Jul 2012
United States
312
I got some copies of rs logix 5, 500 ,and 5000. and also networx, softlogix 5, panelbuilder, and view me. The comp is XP sp3
I went to install. Starting with rs logix 5 and rs linx.
I stopped here after having no success.
I can download everything fine. But when I go to open, it says windows experienced a problem. The only additional comments it has, is that the IP might be an issue or a couple other standard error messages, then I can send an error report.
I have Step 7, indraworks, some other misc plc software on the computer.
But its like AB stuff just wont run on the computer.
Does anyone have any advice?
Also I took a copy of RSLINX and it installed on another computer and opened no problem at all.
also, I seen in another thread, someone had issues with ab stuff because of sql server, I do have sql on my laptop. What exactky i sql server used for? And would it effect anything to uninstall it?
When I installed FT View ME I am pretty sure SQL installed. I was prompted for a Password for it during the installation.
I have seen software installs that get messed up because it wants to install a program that is already on the machine. Maybe if you remove SQL and then install the AB stuff it will install the SQL it needs. Just a guess, might be worth a try.
If RSlinx is running "as a service", then I seem to remember that RSLinx can cause errors when you later try to install RSLogix. You need to shut down RSLinx completely before installing RSLogix.
Hi guys I have s7 v5.4 sp5 on an old Xp laptop which I need to put on a newer laptop I have a windows 7 64 bit laptop which I would like to use...
2,346
I am having trouble installing v21.03. I currently have v19 and v20, installed no problem. I get an error message when the install wizard is...
1,939
Hi, Can anyone help i have tried all morning to set up the aic+ on a micrologix 1200 but i am stuck, what has happened so far i have programed the...
3,128
Hello Everyone! I just installed a new Rosemount X-Stream O2 Flue Gas Transmitter in our boiler and cannot get it to work. The loop is connected...
3,540
I am trying to install a CP343-1 Lean card into an existing system with a S7 315 2DP processor. I have done this before without any trouble. I...
3,685
