patil Member P Join Date Oct 2008 Location pune Posts 6 Oct 13, 2008 #1 How to write the bar code prototocol to identify the componenent with the PLC?
N_ubalde Member Join Date Sep 2008 Location Muntinlupa Posts 3 Oct 13, 2008 #2 PLC make? model? Scanner make? model? Generally, you just need to compare it(bar code reading) by the values you've already programmed. that is if the com is already establish, and you already know the data format.
