help mee :)
m7sallam
Apr 2013
egypt
how to program plc ladder diagram with two outputs for same inputs , that outputs must to run respectively not at the same time ?
welcome to the forum!!!
Are you using a plc? If so what kind?
In your question to my understanding you stated that you are tying to control 2 outputs from the same input, or you want to control 2 outputs from the same input, but not have the outputs on at the same time?? Which one is it? And does it matter which output comes on first or not? Let me know
Is this what you want?
Push a button, output 1 turns on.
Push the button again and output 1 turns off and output 2 turns on.
If so then what you want is called a flip flop or a toggle. Search the forum for the key words flip flop and you'll find tons of examples.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
160
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
106
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
474
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
177
68
