Help. My oc211 isnt work with cj2m cpu35
Hanifbenet
Oct 2018
Tangerang
Hi ihave plc cj2m cpu35 with module input id232 and output oc 211
When i try my program with cx programer. The input in the program is work and green line to go to the coil. But the center on the coil not green (grey). Input module led is on but led from oc 211 is off.
When i force it is work and led oc211 is on it work and it became like it supposed to be normally onn cx programer.what the problem. Thanks
Couple of things to check.
Do a compare of the plc code and your CX-Programmer program.
From the PLC pull down go to Transfer, then Compare.
Are there any Interlock (IL) or Jump (JMP) instructions in your program?
Mr gt. I hve tried to make a new simple program with 1 input and 1 output and upload to plc cpu 35 but even that dosnt work. And i tried with a different plc is cj2m cpu12. And my program work. If i use cpu35 on the cx programmers in my program line will be green but the coil (internal relay or basic relay) is not full green (the circle line is green but on the center circle is gray) It is different from using a CPU 12, the green light on the coil will be full on the circle coil in cx programmer
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
97
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
461
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
173
67
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
560
