Help NetDDE Wonderware to Excel
allscott
Jul 2004
1,332
I currently have a Wonderware application on our plant network and I am trying to display tag values in an Excel spreadsheet on my PC.
After reading the manual I have set up an appplication name of VIEW and Topic name of TAGNAME in the DDE security browser and set the access to Read only, start on connect, and trust share.
In excell I am trying the following command;
\\Wwnode\6750xycom\VIEW|TAGNAME!'Linespeed'
The prefix \\Wwnode\6750xycom is the path to the WW PC on the network. Linespeed is a valid WW tag
Excel gives an error of "cannot open the specified file"
Any idea of what I could be missing?
As always, thanks in advance.
1. Is the computer name actually Wwnode? If not, replace this with the actual computer name.
2. What operating system are you utilizing?
Have you got an = sign in front of the DDE call?
If you have what OS are you using as I can get NetDDE to work on my Win 2000 server but no on the XP laptop.
No, the name of the PC is 6750Xycom, the Wwnode is the workgroup that it was in. I tried it without the Wwnode and still no luck.
The touch panel and my machine are both XP pro
I've tried it with both an = and without
When another Windows application requests a data value from InTouch, it also must know the three I/O address items. The following describes the I/O address convention for InTouch:​
[font=TimesNewRoman,Bold]VIEW [/font][font=TimesNewRoman,Italic](application name) [/font]identifies the InTouch runtime program that contains the data element.
[font=TimesNewRoman,Bold]TAGNAME [/font][font=TimesNewRoman,Italic](topic name) [/font]is the word always used when reading/writing to a tagname in the InTouch database.
[font=TimesNewRoman,Bold]ActualTagname [/font][font=TimesNewRoman,Italic](item name) [/font]is the actual tagname defined for the item in the InTouch Tagname Dictionary.
For example, to access a data value in InTouch from Excel, a DDE Remote​
Reference formula would be entered in the cell into which the data value is to be written:​
=VIEW|TAGNAME!'ActualTagname'
[font=Arial,Bold]Note [/font]If you are networking using Wonderware NetDDE, the [font=TimesNewRoman,Italic]application name [/font]portion of the I/O address must be prefixed with the remote node's name preceded by two backslashes and followed by one backslash. For example:
\\NodeName\VIEW|TAGNAME!'ActualTagname'
Does that make sense? Don't use view use the intouch apllication name. Don't use tagname use the topic name.
I must admit I am a little confused with my naming conventions. In my WW application I have configured an access name as follows;
Application Name:
DASABTCP
Topic Name:
m6750
Protocal:
DDE
This is how WW accesses the PLC (PLC 5/20Ethernet)
So is this the Application and Topic Name I should be using in Excel? Do I have to set this up in the DDE share security configuration?
Thanks again, my head feels a little thick.
I should mention, to clarify, that I had originally set up an application name of "view" and a topic name of "tagname" so that I could follow along with the instructions.
I will try to get a hold of WW tech support in the morning to see if they can help
thanks
hi allscott
Instead of that why don't u try as under
make a tag which u want to displayin excel
Type: - I/O Real or I/O: - Integer
Give appropriate access name say xyz
Node Name : - 6750Xycom
Application : - excel
Topic Name : - all.xls (This file must exist)
Item Name : - r2c2
By configuring NetDde definatly it wii solve the problem
If you are accessing tags from View.exe (Viewer) then the string is:
=\\NodeName\View|Tagname!'ActualTagname'
You would only change the NodeName to match the remote node name and the ActualTagname to match the tag you are looking for.
If you are accessing plc addresses from the IO server, then the string is:
=\\NodeName\DASABTCP|m6750!'PLCAddress'
A quick test you can do if you have Intouch on the local node is:
=View\Tagname\'$Second'
This should show the $second tag counting up 0-59.
Do the same for the remote node:
=\\NodeName\View|Tagname!'$Second'
If the remote gives you an N/A, then check that you can actually ping the nodename by name, check that netdde is running, and check your firewall.
I am having fits with the same thing. I have read things that indicate Windows XP SP2 disables NetDDE and blocks it through the use of its firewall. Not sure though. Does anyone have experience with this?
HI all guru's, I have a Windows2000 SP4 PC with Excel 2000 running on it. I have to interface NetDDE data into Excel from various VAX...
2,432
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
45
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
23
371
please help me . I have to make this ladder diagram and I can’t figure it out :(
356
