Help on S7
sayahan2003
Jun 2006
Calgary
185
Dear Friends
i want to change the CPU of my plc(siemens S7). I know that i must change the type of Cpu in Hardware configuration. My question is , anywhere else i must do any change? i mean, anymore hardware or software change is needed?
You should also check the physical width of your CPU. Just to make sure the new one can fit in the same spot as the old one.
97
22
461
173
67
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
559
