Help on Siemens S5-115U
Gordo777
Jan 2004
We have a machine with a S5-115U PLC which is connected to a Siemens Coros OP35 HMI.
Any help on how/what I would need to upload the PLC program and get the program out of the OP35 ?
We have Step5 v7.1 on a laptop,but with no Com port.
Many thanks.
You will need the 20mA (TTY) to RS232 (serial) converter from Siemens part number. 6ES5 734-1BD20.
As you have no come port you will also need to have a USB to serial interface/converter.
I have used this set up before but it was "slow".
www.process-informatik.de have USB to 20mA interfaces for their PG95 S5/S7 software; although I am unsure if they will work with Siemens S5 software.
For the Op you will require the Protool software.
Hope this helps?
Steve
Thanks Steve for the help.
The PG2000 software + USB>CL cable is probably the way to go.
Cheers.
something I forgot to mention was that Peocess-Informatik have a S5 LAN connector.
This allows the S5 to be connected to "Ethernet"; it is also supplied with software for use with siemens Step 5 that re-directs the "comm" port to Ethernet.
Steve
Can you upload the program from an OP35 ?
I may be wrong, but I think that the upload feature first came with the panels in the "7" series (i.e. OP37).
In any case, an uploaded file from a panel can not be opened and modified in Protool. That functionality came with the Win CE panels.
You must try to find the original Protool program for the OP35.
Hello I'm uninitiated in the world of PLCs; am working on a project which aims to extract data (specfically, machine stop-events based on sensor...
5,083
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
498
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
996
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
352
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
349
