Help on Siemens S5 Software
hagos
Oct 2004
Africa
244
Dear Folks,
It was long time since I worked with Siemens S5 (V5.x) that time, recently I moved to an other company where they use lots of S5 processors , we got a 720 II PG with an S5 V7.x , I tried to go through it, but it took me some time.
What I would like is to first backup all my CPU's & then come down & study them (off line).
I would be vey great full if some one can guide me in simple steps how to back up a CPU program.
Cheers
Hagos
Its also a long time since I've programmed S5, if I had a machine with it on I could be more help, I'm sure someone will help on that regard.
What I would say is, do you have the master commented files for each program. If you download from the CPU, all you will get is the base code with no comments and all your datablocks will display in KH format.
I would strongly recommend, especially if your trying to read and understand the programs, to find the commented files. Make a copy of each and use the copies when comparing and updating the commented program.
If you can help it, do not transfer the program from the CPU to the commented file, as this would change all DB's to KH format and any networks that may be added or deleted would throw your comments out.
I would compare the blocks and carefully modify the block that have changed.
Dear Peter,
At this stage I want only to upload my CPU's , then I'll sit down & try to understand the processes & functions.
So still I'm waiting for your help guys to show me in a simple way how to do that.
Cheers
Hagos
Your going to have a real hard time understanding it without the commented file. You will need the I/O lists and start working back.
There's been threads on doing this as well, don't envy you.
dchartier/Peter
Thank you for the valuable information.
I'd backed up all my CPU's, now as Peter said I'll go the hard way to sit down & study them.
Cheers
Hagos
Can i get some help/advice with Siemens software. I'm a Rockwell guy, but have on site one siemens S7-1500. I wont go into how this plant has a...
1,584
We got a machine in that cam from a division we closed several years ago and we got the machine running but now I am going through all the support...
5,656
Hi everyone, I'm going to start working with an all-SIEMENS project ! So what software I should go ? I tried their website and has been...
3,094
A client just called and asked about transferring a program from one of their op17 to another. The current one has a 'bad button'.. but they don't...
2,644
What software for a project on a cheap budget?!? I can get hold of STEP 5 V7.1 with Auth Disks for around £150. Part Number 6ES5894-0MA04-0UD3...
17
7,548
