help plz
square
Feb 2015
giza
Hello to all
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when download the program from protool, massage display in protool say ( The type of device connected does not match the configured type of device.)
and connect is working
I believe that the message you are getting means that the project you created
does not match the actual device that is connected. Recheck the device versus the project configuration. I could be wrong.
regards,
james
thx james
but i check that,, and Compilation completed successfully
note i transfer that program from op 17 to op 15 with start anew project for op15
Hi Can I get the programming software and data cable name for allen bredly servo drive which model is 2098-DSD-020x?
2,225
I need some assistance to any Siemens Gurus' who can help me convert the following from STL to Lad. I have tried all the old tricks I can...
4,314
Any body here to help me regarding S7-300
1,359
hey evry one i have this problem In the system with S5 CPU 927 it is work ok, but i try to run another four CPU 927 for backup but no one of the...
3,903
sir plz tell me how to interface servo motor with abb micrologoc 1400b plc plz give me detail of instruction and wht type driver may i use or tell...
2,522
