Help print out RSP file
Trispo
Mar 2016
Clermont-Ferrand
I have 2 .RSP files I need to open and print out in PDF for my internhip report and I don't have a license for RSLOGIX 5.
Can someone help me ?
In fact I just need the last ladders from each program, if you print the last 10 ladders program the size must be good.
I know it's a little more longer to do but can you do it ?
I printed both to PDF and uploaded them to WeTransfer:
https://*****/mYsKMQmRod
Also, while printing I did get a few pop-ups that RSLogix could not get a good ladder view, which I have never seen before, so the entire project mey not be printed.
I got the same when opening it.... and also never seen that before
I just reopened it to see if I could find the problem and it has a ladder #82 that is not named as "Lad 82" but "IO Config (Not Used) 82 -" I have never seen before and RSLogix will not open it. And the pop-up appeared when I tried to open ladder 82 in report preview. I had to delete it.
Ladder 23 has a corrupt line comment that takes up pages, I had to delete it to see the ladder.
After that it prints without any error.
And on the second project it has the weird IO Config ladder 57, so I deleted it.
Also, when I verified both projects there were 8 errors each in ladder 8 in both that the "File number doesn't point to the correct file type"
The error free PDF's are at : https://*****/FvYK2DDEqg
A RSP file to be printed out.
I also need help printing out this file. This is a zipped RSP file. It may be corrupt. Not sure. Thanks for the help.
Hi, This has been discussed a bit on this forum so I know there is no alternative program to use to view a PLC-5 RSP file. But would it be...
2,135
Anyone who has experienced "internal error 0005" on the Sprint PLX drive - can you help. I cannot find it in manual. Regards.
1,170
Hello all, I'm fairly new to PLC programming in general, but it is something I get caught up in more and more since I went out on my own in an...
3,667
Hello Everyone, I currently have a project (using AB ControlLogix CPU and Ignition for HMI) as follow: An operator fills a box with xx product...
3,184
I do my EE drawings on 1 sheet. I like this because it keep everything on 1 sheet and you don't have to open 60 different drawing. The hang up...
3,866
