Most likly the shutter has limit switches. You should look at how those are wired. If they are not wired directly into the motor circuit, then you should wire those switches to PLC inputs so that you do not burn out the motor if someone fails to hit the STOP button.
limit switch is built in! so i guess don't need them in your example then?
will test later tonight ..thanks you guys
