John Kerin
A colleague is currently trying to utilise the IEC command "DI_STRNG" in an application at the moment.
He needs to convert two different integers into strings, which then need to be concatenated.
The issue arises when we try to use a second instance of the "DI_STRNG". When the second one is added to the block, we are unable to download it.
Error =
* "Unable to copy the block" D21A
* "Incorrect local data length, or write protection encode fault" Message no. 294:6
We are using "symbolically defined" outputs (i.e. in the local variable table.)
Is it OK to use two instances of "DI_STRING"? or do they need to be dealt with in an indexed stack?
Any other ideas?
Error =
Any other ideas?
