Help to translate a bit of S7 STL into LAD
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
Wondered if someone could help translate the following bit of STL into LAD in S7.
Here is the STL...
Code:
AN M215.2
ON M214.0
A M150.0
O M 4.6
S M141.2
My attempt at translation is:
Code:
 M 215.2                         M141.2
--|/|-----------------------------(S)
 M214.0  M150.0  |
        | M4.6   |
Is this right ?
** EDIT **
I'm also a bit confused by this bit:
Code:
L DBW 382
OPN DB 150
L DBW 24
+I
T MW 34
Am I right in thinking that this is the same as:
Code:
OPN DB 150
L DBW 382
L DBW 24
+I
T MW 34
Or is it:
Code:
L DB(previously opened DB).DBW382
L DB150.DBW24
+I
T MW 34
Many thanks for any help you can give me.
Cheers
Its not right, think about it.
If not m215.2 or not 214.0 and m150.0 or m4.6 then set m141.2.
Then make how you think it is on ladder, and from editor choose show as stl. Then compare to that code.
No. Niranjans code is wrong. It can be written like this, then it will translate to LAD
Code:
 A(
 ON    M    215.2
 ON    M    214.0
 A     M    150.0
 O     M      4.6
 S     M    141.3
Ill try to illustrate what happens in more detail.
Code:
IF NOT M215.2
OR NOT M214.0
= RLO
IF RLO
AND M150.0
= RLO
IF RLO
OR M 4.6
THEN
SET M141.2
For DB it is this one.
Code:
L DB150.DBW24
+I
T MW 34
I only have done LAD diagrams so far and now I got a task to convert these 4 LAD diagrams to FBD and STL. Can anyone help me with that? Thanks!
8,345
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
17
295
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
159
58
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
492
