help with axiom x implements messaging
lunknowl
Oct 2012
vietnam
37
Bar Code Data Object (70 HEX - 1 Instance)
Class Attributes
Attribute ID Name Data Type Default Data
Value
Access
Rule
1 Revision UINT 1 Get
Instance Attributes
Data Value
Access
Rule
1 Bar Code Sequence Number UINT 0 Get
2 Bar Code Status (reserved) UINT 0 Get
3 Bar Code Data Size UINT 0 Get
4 Bar Code Data UINT[ ] varies
(up to 64)
0 Get
5 Last Bar Code Seq. Num Received UINT 0 Get / Set
Common Services
Service Code Implemented for
Class Level Instance Level
Service Name
0EHEX Yes Yes Get Attribute Single
10HEX No Yes Set Attribute Single
hi i try to setup the barcode scanner to controllogix using msg instruction but i dont know how to set it up? what is 70hex- instance man please send me example program if you have it, thanks
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
28
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
446
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
167
62
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
544
