For Troubleshooting / logging motor current I like Fluke's Bluetooth based "Fluke Connect" Series. You're not limited to having an available PLC input, and they are relatively cheap at $200 each.
I like the logging
Fluke a3001-fc It has a flexible current clamp that can fit over thick 350MCM cables, or in tight spaces, and you don't have to break the circuit. The meter can be left to log, for the better part of 2 weeks on a set of 4 AA batteries (with Bluetooth shut off). You can also install the meter in an enclosed panel, and view the readings wirelessly with a PC (or a phone).
To download I recommend the
Fluke PC3000-FC Adapter You cannot use your PC's bluetooth adapter.
Beware they have a Zig-bee based "CNX" line that is incompatible, and inferior.
I will also be honest. The meters are built to Fluke's usual excellent rugged standard, but the software is beyond horrendous. I'm lucky if I can connect in the field, and even when I unplug the meter, bring it to the office, set it next to the adapter, and shut off all neighboring 2.4Ghz Wifi or Bluetooth devices it is slow, and unreliable to download.
The Phone app is even worse. It it beyond "Beyond horrendously" horrible. In addition to having to register for a Fluke account, it fails on downloads continuously. It will also completely abort the download when the maintenance manager calls you to ask how you are making out on the breakdown. They make the app out to be something where the engineer at home can be twirling his mustache and connect with the sparky's phone at the plant and tell him what to do. In reality you can be the engineer at the plant trying to download the data, and the app will fail and crash.
I will have to check the sampling rate, but within each period it will show a min, max, and average current. Throw on three meters and you have each phase. If you're lucky you have some logged data from the PLC to compare against.
