Help with Datalogic Barcode Reader
beethoven_ii
Nov 2006
Central England
409
I have a project using 2 Datalogic DS2400N barcode scanners connected over Profibus to a Siemens S7-315-2 PN/DP processor. The hardware configuration is done, the scanners are working fine through the suppliers 'Genius' software from a laptop but I now need to trigger each scanner independently over Profibus and store the barcode information in a datablock in my plc. I have copied the suppliers sample library project with the necessary FB's, FC's and UDT's into mine but am struggling to get to grips with how to make this work. I have sample code and a load of instruction manuals which cover a wide range of possible applications but finding the bits relevant to what I want to do is almost impossible.
The suppliers of the scanners have no-one who can support me on the plc side of getting this to work, they just buy them in from Italy, nor can they provide me with the name of another company in the UK who have successfully installed a similar set up.
Has anyone in here ever done something similar with Datalogic barcode scanners?
Thanks & Regards,
Barry
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
36
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
297
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
119
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
487
