Help with DH+
TimeFluxCap
Nov 2002
Australia
321
Hi all
Im having problems logging on to a SLC500 that is using DH+ to communicate to a PV1400. Im using a DH+ PCMK card, plugging into the round port on the SLC but RSLinx does not see either of the devices. The one time that I did get online to the SLC it dropped out the comms to the PV. Any ideas welcome
TFC
Is it possible the computer you are using is configured with the same node number as one of the other devices on the network?
I guess its possible that the laptop and PV have the same node number but I didnt think the laptop that I used needed a node number. Correct me if Im wrong.
No problem. I had trouble once when I was trying to connect to a new processor and had the laptop set to the default node of the SLC.
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
86
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
458
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
172
64
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
554
