Help with diagnostic buffer error.
fredz0003
Dec 2010
Houston
186
I am troubleshooting this crane that keeps losing track of the hooks, and well I like to think that something might be wrong with fm350-2 counter. I do have several errors that look really bad like Distributed IO station failure and Module problem or maintenance necessary. I am having problems finding the address, when I go to HW config, then view and address overview, I just can't find 8188.
I could sure use a bit of help in this matter folks, I would appreciate it.🍻
Hi!
Seems to me you have got a Profibus DP issue, and that you will have to check your cabling thoroughly.
Search this forum for;
'Profibus error'
'Profibus grounding'
and you will get lots of useful tips.
Kalle
Edit: The 8188 address is probably related to slave 30.
You are looking for diagnostic address, which just after the Q address in HwConfig.
We have a line that keeps shutting down and the alarming is not very clear on the cause. In the Logix program there are 3 switches that can drop...
1,686
New Forum member Lima0411 recently posted this question to an old thread that had evolved to a discussion of New Zealand rugby, so to start off on...
3,274
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
159
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
106
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
474
