Help with Digi One IAP and Wonderware
garciaortiz
Jan 2008
Dallas
I have a micrologic 1200 connected to a Digi One IAP port 2 (RS-232)which in turn has connected it to the plant network. I seem to be able to go online from the network using RSLinx but I can not get any data to Wonderware.
I am using the DASABCIP server. I added a new ML object and the correct topic in Archestra but the diagnostics show a Comm error.
What am I missing? Do I have to do mapping in the Digi for the Wonderware to get the data? Could it have anything to do with ports? Any help appreciated.
Update:
I was able to get the Wonderware data using RSLinx DDE/OPC as using RSLinx as the application for for the access name.
I would rather move away from this solution and use a wonderware IO Server.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
202
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
109
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
478
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
180
71
